Class "Aimeos\MW\Common\Exception" not found
kdim95
Post by kdim95 » 12 Jun 2023, 19:56
Laravel framework version: 10.12.0
Aimeos Laravel version: ~2023.04
PHP Version: 8.2.6
Environment: Linux
Here is a list of classes in ai-elastic where you still use Aimeos\MW\Common\Exception in 2023.04.
I believe you have you moved on to use only Aimeos\MW\Exception.
  • vendor/aimeoscom/ai-elastic/src/Base/Criteria/Expression/Combine/Elastic.php
  • vendor/aimeoscom/ai-elastic/src/Base/Criteria/Expression/Elastic.php
  • vendor/aimeoscom/ai-elastic/src/Base/Criteria/Expression/Sort/Elastic.php
  • vendor/aimeoscom/ai-elastic/src/Base/Criteria/Elastic.php
I noticed it when I got a search error and it was not throwing the expected exception.
nos3
Re: Class "Aimeos\MW\Common\Exception" not found
Post by nos3 » 13 Jun 2023, 07:57
Thanks a lot for your post!
The wrong exceptions has been fixed and tests has been added. A new release is also tagged.
