Install tasks
vision
Install tasks
Post by vision » 15 Jun 2023, 11:33
Hello!
I want to override aimeos install tasks via creating "/setup" folder with my own tasks in my aimeos-laravel extension. But it doesn't work.
Then I did it via ExtensionServiceProvider and it works:
$this->publishes([
            __DIR__ . '/setup' => base_path() . '/vendor/aimeos/aimeos-core/setup',
], 'my-aimeos-tasks');
The same with "/views":
$this->publishes([
            __DIR__ . '/views' => base_path() . '/vendor/aimeos/aimeos-laravel/src/views',
], 'aimeos-views');
Is there a better way to solve this?
Re: Install tasks
Post by aimeos » 16 Jun 2023, 07:59
You can't overwrite them and can only add new ones that are executed before or after an existing task (according to the dependencies you've configured).
