Translate Fields for Provider Payment
RodolfoBiscaino
Post by RodolfoBiscaino » 18 Jun 2023, 17:31
Hello, I need help.
I'm trying to translate the fields for my new payment provider, but I'm having no success.
I created an array with configs for front-end, following my code:
private array $feConfig = array(
        'mercadopago.holder' => array(
            'code' => 'mercadopago.holder',
            'internalcode'=> 'ccholder',
            'label'=> 'Credit card owner',
            'type'=> 'string',
            'internaltype'=> 'string',
            'default'=> '',
            'required'=> true
        'mercadopago.number' => array(
            'code' => 'mercadopago.number',
            'internalcode'=> 'ccnumber',
            'label'=> 'Credit card number',
            'type'=> 'string',
            'default'=> '',
            'required'=> true
        'mercadopago.year' => array(
            'code' => 'mercadopago.year',
            'internalcode'=> 'ccyear',
            'label'=> 'Expiry year',
            'type'=> 'select',
            'internaltype'=> 'integer',
            'default'=> '',
            'required'=> true
        'mercadopago.month' => array(
            'code' => 'mercadopago.month',
            'internalcode'=> 'ccmonth',
            'label'=> 'Expiry month',
            'type'=> 'select',
            'default'=> array( 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 ),
            'required'=> true
        'mercadopago.cvv' => array(
            'code' => 'mercadopago.cvv',
            'internalcode'=> 'cccvv',
            'label'=> 'CVC code',
            'type'=> 'string',
            'default'=> '',
            'required'=> true
But I can't use these commands phing -f phing.xml i18n inside my package, I follow the commands from documentation https://aimeos.org/docs/latest/developer/translations/
Buildfile: /var/www/html/packages/rodolfo-gateways-pagamento/phing.xml
rodolfo-gateways-pagamento extension > i18n:
     [exec]
     [exec] Warning: The use statement with non-compound name 'Exception' has no effect in /var/www/html/vendor/wisembly/xgettext/bin/xgettext on line 23
     [exec]
     [exec]
     [exec] Warning: Undefined array key "-j" in /var/www/html/vendor/wisembly/xgettext/bin/xgettext on line 44
     [exec]
     [exec] Call Stack:
     [exec]     0.0003     406800   1. {main}() /var/www/html/vendor/wisembly/xgettext/bin/xgettext:0
     [exec]
     [exec]
     [exec] Warning: Undefined array key "-j" in /var/www/html/vendor/wisembly/xgettext/bin/xgettext on line 47
     [exec]
     [exec] Call Stack:
     [exec]
     [exec]
     [exec] Warning: Undefined array key "-f" in /var/www/html/vendor/wisembly/xgettext/bin/xgettext on line 44
     [exec]
     [exec] Call Stack:
     [exec]
     [exec]
     [exec] Warning: Undefined array key "-f" in /var/www/html/vendor/wisembly/xgettext/bin/xgettext on line 47
     [exec]
     [exec] Call Stack:
     [exec]
     [exec]
     [exec] Deprecated: Creation of dynamic property Xgettext\Xgettext::$cli is deprecated in /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Xgettext.php on line 15
     [exec]
     [exec] Call Stack:
     [exec]     0.0142    3379920   2. Xgettext\Xgettext->__construct($files = [0 => '--no-wrap', 1 => '--add-comments=///', 2 => '--language=PHP', 3 => '--from-code=UTF-8', 4 => '--keyword=sprintf:1', 5 => '--keyword=dt:2,2t', 6 => '--keyword=dn:2,3,4t', 7 => '--keyword=translate:2,2t', 8 => '--keyword=translate:2,3,4t'], $output = 'i18n/rodolfo-gateways-pagamento-custom.pot', $keywords = [0 => '_', 1 => 'gettext', 2 => 'ngettext:1,2'], $parser = 'Javascript', $enc = 'UTF-8', $cli = TRUE) /var/www/html/vendor/wisembly/xgettext/bin/xgettext:62
     [exec]
     [exec]
     [exec] Warning: fopen(--no-wrap): Failed to open stream: No such file or directory in /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Parser/AbstractRegexParser.php on line 53
     [exec]
     [exec] Call Stack:
     [exec]     0.0145    3424728   3. Xgettext\Parser\AbstractRegexParser->parse($string = ???) /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Xgettext.php:31
     [exec]     0.0145    3424728   4. fopen($filename = '--no-wrap', $mode = 'r') /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Parser/AbstractRegexParser.php:53
     [exec]
     [exec]
     [exec] Fatal error: Uncaught TypeError: fclose(): Argument #1 ($stream) must be of type resource, bool given in /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Parser/AbstractRegexParser.php on line 100
     [exec]
     [exec] TypeError: fclose(): Argument #1 ($stream) must be of type resource, bool given in /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Parser/AbstractRegexParser.php on line 100
     [exec]
     [exec] Call Stack:
     [exec]     0.0145    3424848   4. fclose($stream = FALSE) /var/www/html/vendor/wisembly/xgettext/src/Xgettext/Parser/AbstractRegexParser.php:100
     [exec]
BUILD FAILED
/var/www/html/packages/rodolfo-gateways-pagamento/phing.xml:34:40: Task exited with code 255
Total time: 0.0668 seconds
I already installed the packages phing and xgettext.
Please someone help me.
kdim95
Re: Translate Fields for Provider Payment
Post by kdim95 » 20 Jun 2023, 09:55
I'm not familiar with the error you are experiencing.
Aimeos admins should help you for what you're trying to do but...
If you want to get your translation working sooner, I can tell you how I'm doing the translations a different way.
I use poedit + a text redactor to edit the .po file (for adding new translations).
When the .po file is saved in poedit, it generates a .mo file, you have to remove the .mo extension from that file and replace the current translation file you have in your i18n directory in your extension.
If your translation does not work after uploading the updated translation file, you should check the config in the file manifest.php in your extension. The path to the config you're looking for is 'i18n' inside manifest.php.
The format of the manifest config is the following:
return [
    'i18n' => [
        '<DOMAIN>' => '<DIRECTORY IN YOUR EXTENSION>'
I hope this helps
Post by aimeos » 21 Jun 2023, 14:21
You can translate codes of your (payment) sevice provider here:
https://github.com/aimeos/ai-client-htm ... dy.php#L91
The translation in your ./config/shop.php for e.g. English and Portuguese would be:
'i18n' => [
	'en' => [
		'client/code' => [
			'mercadopago.holder' => ['Card holder']
	'pt' => [
		'client/code' => [
			'mercadopago.holder' => ['porta-cartões']
RodolfoBiscaino
Post by RodolfoBiscaino » 22 Jun 2023, 13:25
Hey guys,
Thanks for the answer, but I solved it by running the following code:
In my i18n directory
msgfmt --statistics -c -o en en.po
