ElasticSearch - Unable to find product "<Product URL>"
kdim95
Post by kdim95 » 19 Jun 2023, 14:07
Laravel framework version: 10.13.5
Aimeos Laravel version: ~2023.04
PHP Version: 8.2.7
Environment: Linux
Locale: Bulgarian
I'm having problems getting to the product details page.
I have traced the error to this method:
Aimeos\Controller\Frontend\Product::resolve()
	 * Returns the product for the given product URL name
	 * @param string $name Product URL name
	 * @return \Aimeos\MShop\Product\Item\Iface Product item including the referenced domains items
	 * @since 2019.04
	public function resolve( string $name ) : \Aimeos\MShop\Product\Item\Iface
		$search = $this->manager->filter( null )->slice( 0, 1 )->add( ['index.text:url()' => $name] );
		if( ( $item = $this->manager->search( $search, $this->domains )->first() ) === null )
			$msg = $this->context()->translate( 'controller/frontend', 'Unable to find product "%1$s"' );
			throw new \Aimeos\Controller\Frontend\Product\Exception( sprintf( $msg, $name ), 404 );
		return \Aimeos\MShop::create( $this->context(), 'rule' )->apply( $item, 'catalog' );
Something doesn't seem right with this filter index.text:url()
If I change the filter for example to product.url, which I know is indexed in ElasticSearch, it works.
What could be the issue here?
I made my own query for the product in ElasticSearch so you can see what it looks like in the ES index.
Query:
curl -X POST 'localhost:9200/aimeos/_search' -H 'Content-Type: application/json' -d '
    "query": {
        "bool": {
            "should": [
                { "base.product.id": <Product ID> }
Result, some fields I deem irrelevant have been omitted:
  "took" : 3,
  "timed_out" : false,
  "_shards" : {
    "total" : 5,
    "successful" : 5,
    "skipped" : 0,
    "failed" : 0
  "hits" : {
    "total" : {
      "value" : 1,
      "relation" : "eq"
    "hits" : [
        "_index" : "aimeos",
        "_id" : "<Product ID>",
        "_source" : {
          "base" : {
            "product.id" : "<PRODUCT ID>",
            "product.siteid" : "1.",
            "product.ctime" : "2023-02-02 01:16:00",
            "product.mtime" : "2023-06-19 14:40:29",
            "product.editor" : "aimeos:jobs",
            "seen" : 0,
            "orders" : 0,
            "product.url" : "<PRODUCT URL>",
            "product.type" : "book",
            "product.status" : 1,
            "product.dataset" : "",
            "product.datestart" : null,
            "product.dateend" : null,
            "product.scale" : 1.0,
            "product.target" : "",
            "product.ratings" : 0,
            "product.rating" : "0.00",
            "product.instock" : 1,
            "product.boost" : 1.0
          "domains" : [
            "attribute",
            "catalog",
            "media",
            "price",
            "text"
          "index.siteid" : [
            "1."
          "index.price:value(BGN)" : 16.0,
          "index.text:url(bg)" : "<Product URL>",
          "index.text:name(bg)" : "<Product Name>",
          "index.text:url(en)" : "<Product URL>",
          "index.text:name(en)" : "<Product Name>",
Re: ElasticSearch - Unable to find product "<Product URL>"
Post by aimeos » 20 Jun 2023, 07:08
Seems like there was an issue in the resolve() method as it didn't pass the language ID.
Can you update to aimeos/ai-controller-frontend:2023.04.x-dev and see if it works with the latest commit?
kdim95
Post by kdim95 » 20 Jun 2023, 07:56
Thank you, it didn't work at first, but after doing php artisan aimeos:jobs index/rebuild it worked.
Should I remove the "x-dev" package from my composer.json at some point when there is an update to 2023.04 ?
Post by aimeos » 21 Jun 2023, 14:40
A new release of the aimeos/ai-controller-frontend package has been released and you can remove .x-dev now again.
kdim95
Post by kdim95 » 21 Jun 2023, 15:29
Thank you, I've removed the x-dev package and rebuild the index again, there are no issues with the product URLs.
