Custom delivery provider process() not called
kdim95
Post by kdim95 » 30 Jun 2023, 14:13
Laravel framework version: 10.13.5
Aimeos Laravel version: ~2023.04
PHP Version: 8.2.7
Environment: Linux
Hello, the process() method in my custom provider is not being called.
I have this cronjob set (with my own artisan and PHP paths of course, I'm sure it's executing properly because I receive emails):
* * * * * php /path/to/artisan aimeos:jobs "order/export/csv order/email/delivery order/email/payment order/email/voucher order/service/delivery subscription/export/csv customer/email/account"
This is the cut version of my provider:
<?php
namespace Aimeos\MShop\Service\Provider\Delivery;
class MyProvider
	extends \Aimeos\MShop\Service\Provider\Delivery\Base
	implements \Aimeos\MShop\Service\Provider\Delivery\Iface
     * Sends the order details to the ERP system for further processing.
     * @param \Aimeos\MShop\Order\Item\Iface $order Order invoice object to process
    public function process( \Aimeos\MShop\Order\Item\Iface $order ) : \Aimeos\MShop\Order\Item\Iface
		file_put_contents( 'log.txt', print_r( $order, true ) );
        return $order;
Currently it should create a log.txt in the /public when directory when it's called with the order object, but it's not working.
It should work when order/service/delivery is called right? I'm calling the job manually, but process() doesn't seem to get triggered.
Re: Custom delivery provider process() not called
Post by aimeos » 02 Jul 2023, 09:01
The method has been renamed in 2023.04 to push():
https://github.com/aimeos/aimeos-core/c ... 01b82ced85
kdim95
Post by kdim95 » 04 Jul 2023, 13:48
I still can't get it to create a log file from the push() method:
class MyProvider
	public function push( iterable $orders ) : \Aimeos\Map
		file_put_contents( 'log-push.txt', 'test' );
		return map( $orders )->setStatusDelivery( \Aimeos\MShop\Order\Item\Base::STAT_PENDING );
Post by aimeos » 06 Jul 2023, 10:47
Pre-requisites that anything is executed:
- A delivery option with your provider set up in the admin backend
- An order with that delivery option and payment status of "authorized" or "received"
See: https://github.com/aimeos/ai-controller ... #L270-L305
