How to display breadcrumb for the current product category ?
PiotrH
Post by PiotrH » 18 Jul 2023, 07:56
Laravel v9.52.10 aimeos 2023.07 php 8.1.20 Linux
Hi
How to display breadcrumb for the current product category ? It always displaying "Back" link,on single product page, instead of the category link the product belongs.
[img]http://piotrh.net/aimeos.png[/img]
Many Thanks,
Re: How to display breadcrumb for the current product category ?
Post by aimeos » 20 Jul 2023, 09:01
If you hand over the category ID as f_catId=..., then the breadcrumb for that category will be shown. You can add the parameter in your own template which you've copied to your project-specific extension:
https://github.com/aimeos/ai-client-htm ... s.php#L158
To get the category ID use:
$productItem->getRefItems( 'catalog' )->getId()->first()
PiotrH
Post by PiotrH » 20 Jul 2023, 10:10
Hi
Thank you for your reply.
I have changed the code as suggested:
$params = array_diff_key([
'd_name' => $productItem->getName('url'),
'd_prodid' => $productItem->getId(),
'd_pos' => $position !== null ? $position++ : '',
'f_catid' => $productItem->getRefItems( 'catalog' )->getId()->first()
], $detailFilter);
and my url looks like this: /pl/shop/shirt-cap/1?f_catid=1
Breadcrumbs have appeared, but also now an error appears instead of a catalog page menu with message: "A NON-RECOVERABLE ERROR OCCURED"
[img]http://piotrh.net/menu_error.png[/img]
Post by aimeos » 22 Jul 2023, 07:17
Please have a look into the Log panel of the admin backend for error details.
PiotrH
Post by PiotrH » 24 Jul 2023, 06:43
Hi !
It looks like f_catid is not enough - f_name is also required.
/shop/black-shirt-men/0?f_catid=1
Missing required parameter for [Route: aimeos_shop_tree] [URI: shop/f_name~f_catid/l_page?] [Missing parameter: f_name].
I changed my code to:
        'f_catid'  => $productItem->getRefItems('catalog')->getId()->first(),
        'f_name'   => $productItem->getRefItems('catalog')->getName()->first()
    ], $detailFilter);
Now it works.
