Customize mini basket without removing cookie session
ŁukaszSuski-052bagencjareklamowa
Post by ŁukaszSuski-052bagencjareklamowa » 25 Jul 2023, 12:59
Laravel v9.52.10
aimeos 2023.07
php 8.1.20
Linux
I am trying to customize mini basket but to check any new change (e.g html code, not css styles) I have to remove cookie aimeos_session. Is it possible to view my changes faster than this way? Its really not great to remove cookies, being logged out and log in again to check if new change applied.
Re: Customize mini basket without removing cookie session
Post by aimeos » 26 Jul 2023, 11:25
Enable this configuration setting to avoid caching of the mini basket:
https://github.com/aimeos/aimeos-larave ... p.php#L125
Fedi
Post by Fedi » 12 Oct 2023, 23:07
What if I want to disable the whole cookies thing. So I can hit fetch basket and it will show up on every system
Post by aimeos » 13 Oct 2023, 06:48
What do you mean? Can you please explain in more detail?
