Product URL in mini basket
columbo
Post by columbo » 03 Aug 2023, 10:16
how can we add the product url in mini basket?
As the url is not part of basket object I added
data: {'include': 'product'},
parameter, in aimeos.js:
fetch(jsonurl, {
	method: "OPTIONS",
	headers: {'Content-Type': 'application/json'}
}).then(response => {
	return response.json();
}).then(options => {
	fetch(options.meta.resources['basket'], {
		//added to get the product object with product-url / href
	}).then(basket => {
		AimeosBasketMini.updateBasket(basket);
but it is not working
Thank you!
Re: Product URL in mini basket
Post by aimeos » 04 Aug 2023, 05:18
You have to add the URL in the template:
https://github.com/aimeos/ai-client-htm ... #L138-L159
columbo
Post by columbo » 07 Aug 2023, 18:58
ok, now URLs are displayed,
but after adding another product to cart - without reloading the page - all product links are gone
I think .js (aimeos.js, basket-mini.js) has to be edited so that the url gets added to the prototype-item. But I can't find the product url in js.
Post by aimeos » 08 Aug 2023, 10:36
The mini basket is also updated here using the JSON API but it's not possible to get the generated product URLs from there:
https://github.com/aimeos/ai-client-htm ... .js#L9-L71
