Setup Command Multi Shop Duplicate Email
dev_podup
Post by dev_podup » 15 Aug 2023, 10:03
Version info:
Laravel - 8.x, PHP - 8.0, Aimeos - ~2023.04
I am trying to set up multiple shops. I've set the SHOP_MULTISHOP variable to true. But when I try to execute aimeos:setup command for a new site I'm getting this error: "SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'demo@example.com' for key 'unq_lvu_email'". Is there any way to customize or overwrite what data to be used for setup? And if not, is there any other way to solve this issue?
Thank you.
Re: Setup Command Multi Shop Duplicate Email
Post by aimeos » 15 Aug 2023, 10:08
Don't add the demo data to multiple shops as the email address is required to be unique across all sites.
dev_podup
Post by dev_podup » 15 Aug 2023, 10:12
Then when I try to access the new site it's showing laravel exception error page. And anyway it is not working without any default data.
Post by aimeos » 15 Aug 2023, 10:25
Just execute that command:
php artisan aimeos:setup
dev_podup
Post by dev_podup » 17 Aug 2023, 05:54
Thank you, that seems to work.
