ElasticSearch - Remove English indexing, leave only Bulgarian
kdim95
Post by kdim95 » 15 Aug 2023, 14:09
Laravel framework version: 10.16.1
Aimeos Laravel version: 2023.04.*
PHP Version: 8.2.8
Environment: Linux
I'd like to remove the ElasticSearch index for english to improve the speed.
These need to be removed from the index:
  • text:content(en)
  • text:name(en)
  • text:url(en)
Only the bulgarian indexing should remain.
What are the steps to do it?
Currently I have the english locale disabled, but it's still being indexed.
This is what the mapping currently looks like:
"mappings" : {
      "properties" : {
        "attribute" : {
          "type" : "object",
          "enabled" : false
        "base" : {
          "properties" : {
            "orders" : {
              "type" : "long"
            "product" : {
              "properties" : {
                "boost" : {
                  "type" : "float"
                "code" : {
                  "type" : "keyword",
                  "eager_global_ordinals" : true
                "config" : {
                  "type" : "object",
                  "enabled" : false
                "ctime" : {
                  "type" : "date",
                  "format" : "yyyy-MM-dd HH:mm:ss"
                "dataset" : {
                  "type" : "keyword"
                "dateend" : {
                  "type" : "date",
                "datestart" : {
                  "type" : "date",
                "editor" : {
                  "type" : "keyword"
                "id" : {
                  "type" : "keyword",
                "instock" : {
                  "type" : "integer"
                "label" : {
                  "type" : "keyword",
                "mtime" : {
                  "type" : "date",
                "rating" : {
                  "type" : "float"
                "ratings" : {
                  "type" : "integer"
                "scale" : {
                  "type" : "float"
                "siteid" : {
                  "type" : "keyword",
                "status" : {
                  "type" : "short"
                "target" : {
                  "type" : "keyword"
                "type" : {
                  "type" : "keyword",
                "url" : {
                  "type" : "keyword",
            "score" : {
              "type" : "float"
            "seen" : {
              "type" : "long"
        "catalog" : {
          "type" : "object",
          "enabled" : false
        "domains" : {
          "type" : "keyword"
        "index" : {
          "properties" : {
            "attribute" : {
              "type" : "nested",
              "properties" : {
                "id" : {
                  "type" : "keyword",
            "attributeid" : {
              "type" : "keyword",
            "catalog" : {
              "type" : "nested",
              "properties" : {
                "id" : {
                  "type" : "keyword",
                "listtype" : {
                  "type" : "keyword",
                "position" : {
                  "type" : "integer"
            "catalogid" : {
              "type" : "keyword",
            "price:value(BGN)" : {
              "type" : "float"
            "siteid" : {
              "type" : "keyword",
            "supplier" : {
              "type" : "nested",
              "properties" : {
                "id" : {
                  "type" : "keyword",
                "listtype" : {
                  "type" : "keyword",
                "position" : {
                  "type" : "integer"
            "supplierid" : {
              "type" : "keyword",
            "supplierloc" : {
              "type" : "geo_point"
            "tagid" : {
              "type" : "keyword",
            "text:content()" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
                  "ignore_above" : 256
            "text:content(bg)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:content(en)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:name()" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:name(bg)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:name(en)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:url()" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:url(bg)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
            "text:url(en)" : {
              "type" : "text",
              "fields" : {
                "keyword" : {
                  "type" : "keyword",
        "media" : {
          "type" : "object",
          "enabled" : false
        "price" : {
          "type" : "object",
          "enabled" : false
        "product" : {
          "type" : "object",
          "enabled" : false
        "product/property" : {
          "type" : "object",
          "enabled" : false
        "product:has" : {
          "type" : "keyword",
        "product:prop" : {
          "type" : "keyword",
        "supplier" : {
          "type" : "object",
          "enabled" : false
        "text" : {
          "type" : "object",
          "enabled" : false
Re: ElasticSearch - Remove English indexing, leave only Bulgarian
Post by aimeos » 16 Aug 2023, 13:46
The \Aimeos\MShop\Product\Manager\Elastic class contains a getLanguageIds() method which you can overwrite and fetch only active languages.
kdim95
Post by kdim95 » 16 Aug 2023, 14:33
I understand what I need to change.
	 * Returns the language IDs available for the current site
	 * @return string[] List of ISO language codes
	protected function getLanguageIds() : array
		if( !isset( $this->languageIds ) )
			$list = [];
			$manager = \Aimeos\MShop::create( $this->context(), 'locale' );
			$items = $manager->search( $manager->filter()->add( 'locale.status', '==', 1 )->slice( 0, 10000 ) );
			foreach( $items as $item ) {
				$list[$item->getLanguageId()] = null;
			$this->languageIds = array_keys( $list );
		return $this->languageIds;
How do you override this:
I tried the following, didn't work:
'mshop' => [
		'product' => [
			'manager' => [
				'name' => 'ElasticCustom'
<?php
namespace Aimeos\MShop\Product\Manager;
class ElasticCustom extends Elastic
			$list = [];
Post by aimeos » 16 Aug 2023, 14:39
You have to extend the index/text manager instead because it extends from the product manager. Your custom product manager isn't used when indexing.
kdim95
Post by kdim95 » 16 Aug 2023, 15:10
Thanks, that worked 👍
