Help to start custom checkout
justicemuch
Post by justicemuch » 23 Aug 2023, 15:12
Hi I recently started working with Aimeos.
I need some guidance regarding a checkout flow that I want to create .
I want to create a checkout that can go down two different paths depending on the radio button selection they make in the first step.
Is there some documentation I can read to start out ?
Re: Help to start custom checkout
Post by aimeos » 24 Aug 2023, 17:22
The checkout process and how you can adapt it is documented here:
https://aimeos.org/docs/latest/frontend ... omponents/
You can't use two completely different routes during the checkout but you can show one or another output on that page (checkout is one page with several steps).
