Custom delivery attributes not being retained in checkout
MartinKrál
Post by MartinKrál » 26 Aug 2023, 16:21
Laravel 10
PHP 8.1
Aimeos 2023.04
Hi Aimeos,
I created a delivery decorator and I added a custom attribute. Everything works fine for the first order. However if an user is
logged in and makes another order, payment and delivery checkout steps will be skipped as they are automatically using values from previous order - the problem is that the custom attribute is not being retained.
Only way for the user to fix this is to go manually to delivery checkout step and select the attribute.
I´d like to know how I can fix this and if it´s not simple, can I somehow disable the logic that retains payment and delivery selections from previous order?
Thank you.
Best regards,
Martin
Re: Custom delivery attributes not being retained in checkout
Post by aimeos » 27 Aug 2023, 07:36
We've fixed that last week in dev-master and it will be part of the next 2023.10 LTS release in October :-)
