How to filter product text by API (jsonadm and graphql) request
ИванМаксимов
Post by ИванМаксимов » 06 Sep 2023, 17:36
Please, help me write API request to get long english text for a given product. For graphql or jsonadm API.
I try graphql request (on default demo data):
"query":"query { getProduct(id:\"15\", include: [\"product/text\"]){ id,type,label,lists{text(listtype: \"default\", type: \"long\") { id, item (languageid: \"en\") { type label languageid } } } }}"
But get error:
"message":"Unknown argument \"languageid\" on field \"item\" of type \"productliststextOutput\".
I try for just check filtering text attrs feature :
"query":"query { searchProducts( include: [\"product/text\"], filter: \"{\\\"==\\\":{\\\"product/text.type\\\":\\\"long\\\"}}\" ){ id,type,label,lists{text(listtype: \"default\", type: \"long\") { id, item { type label languageid } } } }}"
or product.text.type
But get error:
{"errors":[{"message":"Internal server error","locations":[{"line":1,"column":9}],"path":["searchProducts"]}],"data":{"searchProducts":null}}
Env:
"aimeos/aimeos-laravel": 2023.07.01
"laravel/framework": v10.21.0
php 8.1
Docker
Mac
Re: How to filter product text by API (jsonadm and graphql) request
Post by aimeos » 06 Sep 2023, 17:49
This should work:
query {
  searchProducts(filter: "{}", include: ["product/text"]) {
    id
    type
    code
    label
    lists {
      text(listtype: "default", type: "long") {
        id
        item {
          type
          domain
          languageid
          label
ИванМаксимов
Post by ИванМаксимов » 06 Sep 2023, 18:02
This worked, but i ask about "english" text!
How to filter by languadeid field value?
Post by aimeos » 06 Sep 2023, 18:18
You can't. The GraphQL API is for administration purpose only and you can't limit the texts of the product by any property because you need to pass all texts when you save them again. Texts with are not sent in the request are deleted.
ИванМаксимов
Post by ИванМаксимов » 06 Sep 2023, 18:42
aimeos wrote: 06 Sep 2023, 18:18 You can't. The GraphQL API is for administration purpose only and you can't limit the texts of the product by any property because you need to pass all texts when you save them again. Texts with are not sent in the request are deleted.
Ok. What about jsonadm ? By jsonadm API it's possible?
ИванМаксимов
Post by ИванМаксимов » 06 Sep 2023, 18:46
And the next question: how to update the content of one text for a product?
Pease, give example request of update one text of existing product
Post by aimeos » 07 Sep 2023, 08:24
The JsonAdm API allows updating single items but it's deprecated and you shouldn't use it any more because it will be removed in the future.
With the GraphQL API, you can update all (text) items at once (pass those you didn't modify too, otherwise the will be deleted):
mutation {
  saveProduct(input: {
    code: "test"
    label: "Test product"
    lists: {
      text: [{
        type: "default",
        item: {
          content: "...",
          label: "...",
      	  languageid: "..."
    id
ИванМаксимов
Post by ИванМаксимов » 07 Sep 2023, 09:35
Thank you so much!
aimeos wrote: 07 Sep 2023, 08:24
mutation {
    code: "test"
    lists: {
      text: [{
        type: "default",
type: "default" <--- is it a list entry type? where can I find out what types are available and what they are for?
Post by aimeos » 08 Sep 2023, 07:03
ИванМаксимов wrote: 07 Sep 2023, 09:35 type: "default" <--- is it a list entry type? where can I find out what types are available and what they are for?
Have a look into the "Types > Product lists" panel in admin backend. There you can see the available types and can add your own. They can be used in the frontend for additional grouping of referenced items but for texts, their value is almost always "default" (which you can skip because it's also the default value).
