Get individual products from bundle product
lockhart97
Post by lockhart97 » 09 Sep 2023, 04:38
Laravel framework version: 10.18.0
Aimeos Laravel version: 2023.07
PHP Version: 8.2.8
Environment: Linux
Hello Aimeos,
I have bundle products and I want to get details of products added to that bundle. Is there any way to do that using JsonAPI or any other way. I looked through documentation and forums but I did not find any solution.
Re: Get individual products from bundle product
Post by aimeos » 09 Sep 2023, 05:05
Use "include=product" to get related products like bundled articles in one request with the bundle product.
lockhart97
Post by lockhart97 » 09 Sep 2023, 05:48
using "include=product" returns only suggested products and products bought together, but not products in bundle.
Post by aimeos » 09 Sep 2023, 06:17
"include=product" returns bundle articles and variant articles of selection products too:
https://laravel.demo.aimeos.org/jsonapi ... oduct.type
Check your bundled products if it doesn't.
lockhart97
Post by lockhart97 » 09 Sep 2023, 08:17
Yes, you are right. I checked, it's working.
But the problem is that when I add bundle products using "xml import", in admin panel it shows bundle products has products in bundle but these products are not returned using JsonAPI. Now, when I delete all products in bundle and add same products manually through admin panel, API now returns correct data.
What can be reason for this? Adding bundle products using "xml import" does not return products in bundle but other associated products like, suggested products are returned.
lockhart97
Post by lockhart97 » 09 Sep 2023, 08:28
lockhart97 wrote: 09 Sep 2023, 08:17 Yes, you are right. I checked, it's working.
Got it. It was my mistake. After some hit and trial I found the problem. The products in bundle had "dateend" option set to year 2000. I set a date in future and it started returning correct data.
Thank you so much for the help.
