Admin panel
- мужыковмужыков
Admin panel
When I installed aimeos package in my Laravel project (with Jetstream) I tried to go to the admin page (path: /admin) I was redirected to /dashboard of Laravel app. How can I have access to the admin page?
Re: Admin panel
You user must have super, admin or editor privileges and you can create such users (or update existing users) by executing:
php artisan aimeos:account --super <email>Professional support and custom implementation are available at Aimeos.com
- мужыковмужыков
Re: Admin panel
I created a super account but I still redirect to Laravel dashboard. Do I need to add additional configuration to the route file or something else?aimeos wrote: 05 Oct 2023, 09:37 You user must have super, admin or editor privileges and you can create such users (or update existing users) by executing:Code: Select all
Re: Admin panel
If you don't use the Aimeos distribution, standard Laravel setups always redirect to the dashboard after login by default instead of the last URL. Check the files in the ./app/Http/ directory.
- мужыковмужыков
Re: Admin panel
what should be there? Do I need to add something?aimeos wrote: 06 Oct 2023, 08:08 If you don't use the Aimeos distribution, standard Laravel setups always redirect to the dashboard after login by default instead of the last URL. Check the files in the ./app/Http/ directory.
Re: Admin panel
The Aimeos distribution uses Laravel Breeze instead of Jetstream so it may require changing different files. In the distribution, these lines are relevant:
- https://github.com/aimeos/aimeos/blob/m ... er.php#L20
- https://github.com/aimeos/aimeos/blob/m ... er.php#L33
