SSL certificate problem: certificate has expired
hadoo
Post by hadoo » 10 Oct 2023, 12:00
hello aimeos team
i have create extension from aimeos extenstion builder and download it
when mad command:
composer req aimeos-extensions/sellers
return this error
In CurlDownloader.php line 372:
curl error 60 while downloading https://packages.aimeos.org/aimeoscom/packages.json: SSL certificate problem: certificate has expired
by the way i have purchasesd aimeos B2B
hadoo
Re: SSL certificate problem: certificate has expired
Post by hadoo » 10 Oct 2023, 13:02
https://packages.aimeos.org/aimeoscom your website ssl expired
Post by aimeos » 10 Oct 2023, 13:31
We are aware of the problem since this morning and try to find out why the certificate can't be renewed by our Kubernetes environment. Currently affected are:
- packages.aimeos.org (cert not renewed)
- admin.demo.aimeos.org (deployment fails due to cert problem on packages.aimeos.org)
- laravel.demo.aimeos.org (deployment fails due to cert problem on packages.aimeos.org)
hadoo
Post by hadoo » 10 Oct 2023, 13:42
when you solve this problem notify me
Post by aimeos » 10 Oct 2023, 14:34
Problem has been fixed now, there's a new certificate issued for the domain.
Thank you for your patience :-)
