Extend vendor to seller request package
hadoo
Post by hadoo » 12 Oct 2023, 13:12
Hello aimeos team
I want to add new panel in admin (sellers requests) the logic its will be accept or reject them.
I used your topic : creating managers
but it is not worked for me .
1-how to get the sellers request data ?
2-how to present this data in blade page ?
3-how to create action to approve or reject sellers requests ?
Can you explain to me step by step please ?
Re: Extend vendor to seller request package
Post by aimeos » 13 Oct 2023, 14:31
First of all: What is a seller request in your terminology?
hadoo
Post by hadoo » 23 Oct 2023, 11:21
seller request mean when any user make register i would not made for him site,
i will review his documents after that maybe i will accept him or reject him.
Post by aimeos » 26 Oct 2023, 07:47
The easiest way would be to set newly registered accounts to "review" (-1) here:
https://github.com/aimeos/aimeos/blob/m ... er.php#L68
Then, they are able to use the backend but can't sell their products.
If you don't want them to get an account at all until you create one for them, just create an e-mail with the documents using the Laravel API and send them to your own e-mail account. You don't need to extend Aimeos for that because registration and authentication is completely done using Laravel means.
