Losing session at basket modification
- Wall0fDeath
Php : 8.2
Os: Debian GNU/Linux 11 (Bullseye)
Aimeos 22.10.12
Laravel 9.52.16
Dear Aimeos Team,
I have a weird problem when I try to run the shop with "nginx and php 8.2 fpm":
- When I click to add a product to the basket(or any basket action, or checkout), it does, but i will lose my session after the click to these actions. I saw 2 product on the mini basket and when I add 1 product, it changes to 0 and at the next request, what needs login i will get 419 error, or it just redirects me out to login.
If I do the same with "php artisan serve" instead of nginx, it works normally, I won't lose my session, i can modify basket, make an order etc.
I have checked every log, both for laravel, and nginx, but nothing seems to be related to this.
May I ask your idea about this?
Aimeos 22.10.12
Laravel 9.52.16
Dear Aimeos Team,
- Wall0fDeath
Re: Losing session at basket modification
Nginx conf relevant part for php:
location ~ \.php$ {
satisfy any;
## -- allowed ip addresses --
allow 10.13.248.0/24;
allow 192.168.254.0/24;
deny all;
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd-devel;
include snippets/my-fastcgi-php.conf;
fastcgi_intercept_errors on;
access_log /var/log/nginx/postdata-php.log postdata;
#fastcgi_pass unix:/run/php/php-fpm.sock;
fastcgi_pass 127.0.0.1:9000;
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
fastcgi_param REMOTE_ADDR $cliaddr;
Seems like you've lost your cookies
- Wall0fDeath
Thank you for your answer!
The problem was the following:
I added session creation for api midlewares to be able to use the jsonadm calls. (bc. of the csrf protection)
That made some problems in the force...
So i added the same routes with different middlewares and different names, so they can live peacefully next to each other now.
