Class web does not exist
anders
Post by anders » 01 Feb 2016, 15:13
Hi guys,
I'm sure I'm doing something wrong as I'm trying to integrate the laravel aimeos package into an existing site :oops:
ReflectionException in Container.php line 741:
I having an issue whereby I'm getting a complaint that Class web does not exits.
Working off of Laravel 5.2.
Hoping someone might be able to steer me in the right direction?
Cheers,
A
Re: Class web does not exist
Post by aimeos » 01 Feb 2016, 16:03
That doesn't look like an Aimeos problem in the first place.
Could you please post the stack trace nevertheless?
Karthick
Post by Karthick » 23 Mar 2016, 12:18
Hi there,
I have also same error while running 'Test installation' step.
Here is the 'stack trace nevertheless':
at ReflectionClass->__construct('web') in Container.php line 741
at Container->build('web', array()) in Container.php line 631
at Container->make('web', array()) in Application.php line 674
at Application->make('web') in Pipeline.php line 123
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 103
at Pipeline->then(object(Closure)) in Router.php line 710
at Router->runRouteWithinStack(object(Route), object(Request)) in Router.php line 675
at Router->dispatchToRoute(object(Request)) in Router.php line 635
at Router->dispatch(object(Request)) in Kernel.php line 236
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 139
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in ShareErrorsFromSession.php line 49
at ShareErrorsFromSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(ShareErrorsFromSession), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 124
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in StartSession.php line 62
at StartSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartSession), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 124
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in AddQueuedCookiesToResponse.php line 37
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
at call_user_func_array(array(object(AddQueuedCookiesToResponse), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 124
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in EncryptCookies.php line 59
at EncryptCookies->handle(object(Request), object(Closure))
at call_user_func_array(array(object(EncryptCookies), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 124
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in CheckForMaintenanceMode.php line 44
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
at call_user_func_array(array(object(CheckForMaintenanceMode), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 124
at Pipeline->then(object(Closure)) in Kernel.php line 122
at Kernel->sendRequestThroughRouter(object(Request)) in Kernel.php line 87
at Kernel->handle(object(Request)) in index.php line 54
Could you please help me?
Cheers,
Karthick S
Post by aimeos » 23 Mar 2016, 12:39
If you are using Laravel 5.1, the middleware array in ./config/shop.php must not contain the "web" middleware because this is new in Laravel 5.2. Please have a look at https://github.com/aimeos/aimeos-larave ... -or-update (last paragraph).
Karthick
Post by Karthick » 23 Mar 2016, 12:50
Thank you very much.
Its working fine.
