Modules
geramv22
Modules
Post by geramv22 » 09 Nov 2023, 15:10
Hello everyone, I have a problem that I cannot find in the aimeos 2023 documentation, I have created an extension with the available tool and I want to include an override for the routes within the module itself, as it should be done, thank you!
Re: Modules
Post by aimeos » 10 Nov 2023, 07:49
Disable the route groups in your ./config/shop.php by setting them to "false":
https://github.com/aimeos/aimeos-larave ... hp#L13-L30
Then, copy the routes you've disabled to your ./routes/web.php file:
https://github.com/aimeos/aimeos-larave ... aimeos.php
geramv22
Re: Modules
Post by geramv22 » 10 Nov 2023, 08:12
aimeos wrote: 10 Nov 2023, 07:49 Disable the route groups in your ./config/shop.php by setting them to "false":
Thanks is ok, but i need override files web.php or aimeos.php in my extension don't modify files kernel aimeos or laravel, thanks, I don't know if it's possible
Re: Modules
Post by aimeos » 10 Nov 2023, 08:23
Only change files in your Laravel application, not in the ./vendor/ directory, so .../app/config/shop.php and .../app/routes/web.php are the right files.
