Doesn't modify the frontend when models are updated with jsonapi
Ashley23
Post by Ashley23 » 10 Nov 2023, 08:27
Laravel framework version: 10.8.0
Aimeos Laravel version: 2023.04.*
PHP Version: 8.1.18 (cli)
Environment: Linux (Ubuntu)
When the models are updated with jsonapi, everything is accurate in admin panel, but things in the frontend doesn't seem so. Especially when they are changed.
For example, in the beginning 'A' product is included to 'First' category everything is okay. And the 'A' product's category is changed to 'Second' category with jsonapi, in the admin panel the 'A' product has 'Second' category but in the front-end the 'A' product is included to 'First' category. Then, when that 'A' product is just resaved in admin panel, everything is okay.
Is this problem associated with api controller or with caches?
PS: I've tried clearing all caches, didn't work either.
Re: Doesn't modify the frontend when models are updated with jsonapi
Post by aimeos » 14 Nov 2023, 07:51
Most likely because the product index isn't updated when you change a product using the JsonAdm API. You have to use the "index" endpoint of the JsonAdm API to rebuild the index for the passed product IDs:
POST /admin/default/jsonadm?resource=index
body: {"data": ["<id>","<id>"]}
