Admin Js file extension to project
rohith.jayaraj
Post by rohith.jayaraj » 29 Nov 2023, 07:25
how to extend file "npkmarket\vendor\aimeos\ai-admin-jqadm\js\apps\price.js " to Aimeos Laravel Project ? .
We have this custom package folder, so i have tried copy pasting this file to \packages\npk\themes\admin\jqadm\price.js but it didn't work.
Also tried to mention file path inside manifest.jsb2, but it didn't help either?
So can you please assist on how to extended Js file to our project ?
rohith.jayaraj
Re: Admin Js file extension to project
Post by rohith.jayaraj » 29 Nov 2023, 08:04
An update to this issue: Was able to find out the cause of this issue, when we extend a vue js file from vendor to our project. Both instances will run at same time which will cause conflicts and we won’t be able to see any error in console
When i tried to comment whole inside vendor folder, its working fine with our custom file
Post by aimeos » 01 Dec 2023, 12:13
Don't copy complete JS file but overwrite the function you want to change instead.
Also, never change the files in the ./vendor/ directory or you will burn in developer hell!
