Can't Overide template
MPOUAMONWAKPARE-AMEY(spero)
Post by MPOUAMONWAKPARE-AMEY(spero) » 02 Dec 2023, 12:56
Hello, thanks for the good job you are doing.
I get stuck overiding templates
Aimeos 2023
Laravel 10
I install extension like said from the documentation using composer
I create new extension from generator like recommanded, then copy it in a foder named packages in the root of my project and i copy content of templates folder from ai-client-html and put it in my extension templates folder.
When I comment or change for eg the content of packages/my-extension/templates/catalog/home/body.php nothing seems to be changed.
PS i disbled cache from config file: shop.php and use also aimeos:clear command
Re: Can't Overide template
Post by aimeos » 02 Dec 2023, 14:14
The path to the file must be:
packages/my-extension/templates/client/html/catalog/home/body.php
