Add a new delivery provider
WGSF
Post by WGSF » 06 Dec 2023, 15:33
Laravel 10.35
Aimeos Laravel ~2023.07
PHP 8.1.16
I had already created my own delivery Provider with Aimeos 2022.10 and it was working well.
With 2023.07, I created a Myprovider class in Myprovider.php file under packages/myextension/src/MShop/Service/provider/Delivery/
namespace Aimeos\MShop\Service\Provider\Delivery;
class Myprovider
    extends \Aimeos\MShop\Service\Provider\Delivery\Base
    implements \Aimeos\MShop\Service\Provider\Delivery\Iface
After a composer update, I can see the class in autoload_classmap.php
    'Aimeos\\MShop\\Service\\Provider\\Delivery\\Email' => $vendorDir . '/aimeos/aimeos-core/src/MShop/Service/Provider/Delivery/Email.php',
    'Aimeos\\MShop\\Service\\Provider\\Delivery\\Iface' => $vendorDir . '/aimeos/aimeos-core/src/MShop/Service/Provider/Delivery/Iface.php',
    'Aimeos\\MShop\\Service\\Provider\\Delivery\\Myprovider' => $vendorDir . '/aimeos-extensions/aiext/src/MShop/Service/Provider/Delivery/Myprovider.php',
Now, in the admin side, When doing Setup > Service and add a new service with type= Delivery, Provider allow me to select 'Email', 'Standard' and 'Xml' But not 'Mydelivery'.
Can you see what I have missed ?
Many thanks,
Re: Add a new delivery provider
Post by aimeos » 07 Dec 2023, 12:37
There was an issue in the manifest.php file of generated extensions because the "include" key was missing. If you add these lines, your delivery provider will be found:
https://github.com/aimeos/aimeos-core/b ... hp#L27-L29
WGSF
Post by WGSF » 07 Dec 2023, 16:10
That works !
Thank you
