add from order-history with deactivated products -> error
columbo
Post by columbo » 08 Dec 2023, 12:54
all products are listed in the order history as available, even if they have been deactivated in the meantime.
  1. customer adds a "history-basket" to his current basket
  2. history-basket contains at least one deactivated product
  3. -> Error Eintrag mit ID "1234" in "product.id" nicht gefunden {"userId":1,"exception":"[object] (Aimeos\\MShop\\Exception(code: 404): Eintrag mit ID \"1234\" in \"product.id\" nicht gefunden at \\vendor\\aimeos\\aimeos-core\\src\\MShop\\Common\\Manager\\DB.php:635)
Plugin "Checks for deleted products" (ProductGone) is enabled
I tried to get the product.status in account history to
  • exclude deactivated products from being added to customers basket
  • highlight products that are currently not available / deactivated
but I have not found a working solution
What is your recommendation and the most efficient solution?
Thank you.
Re: add from order-history with deactivated products -> error
Post by aimeos » 10 Dec 2023, 11:07
The ProductGone plugin is only used if the product is already in the basket but removed before the checkout is completed.
The best option might be to catch the product exceptions here and add an error message to the basket view that at least one product couldn't be added to the basket:
https://github.com/aimeos/ai-client-htm ... #L192-L229
Are you able to provide a PR for the change?
columbo
Post by columbo » 11 Dec 2023, 17:16
tried to create a PR but not sure if done right.
addProducts() function with try/catch:
protected function addProducts( \Aimeos\Base\View\Iface $view )
		$context = $this->context();
		$domains = ['attribute', 'catalog', 'media', 'price', 'product', 'text', 'locale/site'];
		$basketCntl = \Aimeos\Controller\Frontend::create( $context, 'basket' );
		$productCntl = \Aimeos\Controller\Frontend::create( $context, 'product' )->uses( $domains );
		if( ( $prodid = $view->param( 'b_prodid', '' ) ) !== '' && $view->param( 'b_quantity', 0 ) > 0 )
			try
				$basketCntl->addProduct(
					$productCntl->get( $prodid ),
					(float) $view->param( 'b_quantity', 0 ),
					(array) $view->param( 'b_attrvarid', [] ),
					$this->getAttributeMap( $view->param( 'b_attrconfid', [] ) ),
					array_filter( (array) $view->param( 'b_attrcustid', [] ) ),
					(string) $view->param( 'b_stocktype', 'default' ),
					$view->param( 'b_siteid' )
			catch( \Exception $e )
				//eg. product has been deactivated
				$msg = $view->translate( 'client', "At least one product couldn't be added to the basket." );
				$view->errors = array_merge( $view->get( 'errors', [] ), [$msg] );
		else
			foreach( (array) $view->param( 'b_prod', [] ) as $values )
				if( ( $values['prodid'] ?? null ) && ( $values['quantity'] ?? 0 ) > 0 )
					try
						$basketCntl->addProduct( $productCntl->get( $values['prodid'] ),
							(float) ( $values['quantity'] ?? 0 ),
							array_filter( (array) ( $values['attrvarid'] ?? [] ) ),
							$this->getAttributeMap( (array) ( $values['attrconfid'] ?? [] ) ),
							array_filter( (array) ( $values['attrcustid'] ?? [] ) ),
							(string) ( $values['stocktype'] ?? 'default' ),
							$values['siteid'] ?? null
		$this->clearCached();
Are there any options to highlight products that are currently not available / deactivated?
eg. set a "currently not availabe" badge or change to productname-color
thank you
Post by aimeos » 12 Dec 2023, 12:41
Thanks! Highlighting products upfront is only possible if the original products are loaded too in the history view. It's possible to add "product" to the list of fetched domains here:
https://github.com/aimeos/ai-client-htm ... hp#L70-L83
