Aimeos default theme change using extension
I have doubt again in Aimeos extension( Using latest version of aimeos). Now my need is to change the look and feel of site. At the same time ,the extra field also added to admin section.
1)Do both need separate extension? If theme and functionality change need two extensions, what should be noted(locally and while uploading to server)
2)If not required ,how can I override the default theme with my theme?
For eg :I can add an extra field with the aimeos extension and can I change the header and footer style using the same extension? When I do this ,the default styles are applied.
Thanks in advance.
Thanks in advance.
Re: Aimeos dafault theme change using extension
You only need one extension, if you want to change only templates or add features, use the Aimeos extension. If you want to create your own theme in addition, only use the Laravel theme extension.archanaep wrote: 28 Dec 2023, 09:43 1)Do both need separate extension? If theme and functionality change need two extensions, what should be noted(locally and while uploading to server)
The theme CSS/JS files are copied to ./public/vendor/shop/themes/default/ directory where you can adapt the content of the files. For that, no separate (theme) extension is required.archanaep wrote: 28 Dec 2023, 09:43 2)If not required ,how can I override the default theme with my theme?
For adding an extra field, an Aimeos extension is required in the ./packages/ directory. To adapt the header and footer without a theme extension, you can copy the base.blade.php file from the aimeos/aimeos-laravel extension to the ./resources/views/vendor/shop/ directory:archanaep wrote: 28 Dec 2023, 09:43 For eg :I can add an extra field with the aimeos extension and can I change the header and footer style using the same extension? When I do this ,the default styles are applied.
https://aimeos.org/docs/latest/laravel/ ... -templates
Re: Aimeos default theme change using extension
Thankyou for your response. Can I create a custom.css file for client html(without theme extension)?If yes how to link like aimeos.css? Overrides some style in aimeos.css file in default folder but not reflected. How to publish the CSS/js folder from extension to public?
Copy the ./vendor/aimeos/aimeos-laravel/views/base.blade.php file to ./resources/views/vendor/shop/base.blade.php and add the CSS file in the header of the HTML page output.
See: https://aimeos.org/docs/latest/laravel/ ... -templates
