Tennant just have default product option when try to create product
AleksandarJovanovic
Post by AleksandarJovanovic » 02 Jan 2024, 12:23
Aimeos version 2023.10
Php: 8.1
Linux
I am utilizing the multi-shop functionality provided by the Aimeos Laravel package. I have successfully created one tenant, although not through the registration form, but rather via the admin panel in the Locale/Site section, and it is functioning properly.
However, when attempting to create an article from the tenant's admin panel, I only see the default product. I am unable to use bundles, subscribe to events, or manage groups, among other functionalities.
P.S. When I register a new shop using the registration form, everything works as intended.
Wishing you a Happy New Year and all the best!
Alex :)
Re: Tennant just have default product option when try to create product
Post by aimeos » 04 Jan 2024, 08:27
If you create a new tenant via the admin backend in a SaaS setup, you have to execute the setup tasks manually:
php artisan aimeos:setup <newsite>
AleksandarJovanovic
Post by AleksandarJovanovic » 06 Jan 2024, 14:51
Thank you very much. I added one tenant, and it works. However, when I try to delete the old tenant, an error shows up. Could you please tell me if there's a command to delete a tenant via the terminal?
Best regards,
Alex
Post by aimeos » 09 Jan 2024, 11:22
There's no way to delete a site from the CLI yet.
Deleting a site in the admin backend causes an error because the site is deleted but the next request to display the admin panel still refers to that site. Maybe redirecting to / might be an option?
