Translate frontend and backend
AleksandarJovanovic
Post by AleksandarJovanovic » 15 Jan 2024, 12:27
Aimeos version 2023.10
Php: 8.1
Linux
Dear,
I make extension and translate backend from i18n. But in that folder is just backend .po file in my language. I try to add another .po file from client folder but is duplicated and cant paste there.
What to do to translate both, admin and frontend file.
Shoud i make new extension with name frontend translate and do work there or have some better option.
Tnx
Re: Translate frontend and backend
Post by aimeos » 18 Jan 2024, 14:48
If there are translations missing, please add them at transifex (just register and start translating):
https://app.transifex.com/aimeos/
In the .po file of your language in the ./i18n/ directory of your own extension, just add the translations you want to *overwrite* and compile them to a MO file afterwards:
https://aimeos.org/docs/latest/develope ... s/#gettext
