Dashboard doesn't return full date range
Version: 2022.10
I need to extend the dashboard, but before I can do that, I came across that our dashboard is not returning all of data:
The params seem to be sent with correct date range, but it gets lost into manager somehow:
"$view->param()"
"$view->data"
What could be culprit for this wrong data? The base dashboard has not been altered in any way.
"$view->param()"
array(8) {
["site"]=>
string(7) "default"
["resource"]=>
string(5) "order"
["locale"]=>
string(2) "en"
["aggregate"]=>
string(33) "order.base.currencyid,order.cdate"
["filter"]=>
array(1) {
array(4) {
[0]=>
array(1) {
array(1) {
["order.statuspayment"]=>
string(1) "5"
[1]=>
array(1) {
array(1) {
["order.ctime"]=>
string(19) "2023-12-17T00:00:00"
[2]=>
array(1) {
array(1) {
["order.ctime"]=>
string(19) "2024-01-16T23:59:59"
[3]=>
array(1) {
array(2) {
[0]=>
array(1) {
array(1) {
["order.base.product.statuspayment"]=>
string(2) "-1"
[1]=>
array(1) {
array(1) {
string(1) "5"
["sort"]=>
string(12) "-order.ctime"
["value"]=>
string(26) "order.base.product.total()"
["type"]=>
string(3) "sum"
object(Aimeos\Map)#1851 (2) {
["list":protected]=>
array(1) {
["EUR"]=>
array(13) {
["2024-01-03"]=>
float(8.99)
["2024-01-04"]=>
float(149.98)
["2024-01-05"]=>
float(100.96999999999998)
["2024-01-06"]=>
float(26.99)
["2024-01-07"]=>
float(19.99)
["2024-01-09"]=>
float(53.99)
["2024-01-10"]=>
float(75.98)
["2024-01-11"]=>
float(242.95)
["2024-01-12"]=>
float(184.95999999999998)
["2024-01-13"]=>
float(76.98)
["2024-01-14"]=>
float(175.98)
["2024-01-15"]=>
float(48.97)
["2024-01-16"]=>
float(67.98)
["sep":protected]=>
string(1) "/"
