Serial for product
chiodimassimiliano
Serial for product
Post by chiodimassimiliano » 02 Feb 2024, 11:29
Good morning,
I would like to try to create a table for the products that I would like to call serial_number: inside there will be the serial numbers for a hypothetical 'software' type product;
the serial numbers will contain the licenses; and will be visible on the invoice only after payment has been made (.
a license code for each single quantity of each product in the cart:
Product 1 - Software Test, Qty 2
- Serial 2384923849020384
- Serial 2384923849020385
Product 2 - Software Test 2, Qty 1
How can I do ? I understand nothing about Aimeos and little about Laravel
chiodimassimiliano
Re: Serial for product
Post by chiodimassimiliano » 02 Feb 2024, 13:54
maybe someone who could try to help me...
Post by aimeos » 05 Feb 2024, 11:13
That's a bit advanced if you don't have experience with Laravel and Aimeos.
How to create a new table and an Aimeos manager for it is described here:
https://aimeos.org/docs/latest/models/create-managers/
The problem is now that you need to add the license code to the products in the basket. This can be done by a basket plugin that registers for the "addProduct.after" event, looks up the next license code if the product in the basket doesn't already have one and add the license code as attribute to the product in the basket:
https://aimeos.org/docs/latest/provider ... t-plugins/
