Error creating a project extension
iwpress
Post by iwpress » 04 Feb 2024, 20:31
Hello Aimeos,
aimeos/ai-laravel v.2023.10.4 Laravel v.10.43.0 PHP v.8.1.27, MacOS 14.2
I am at the very beginning of my journey. I want to make an extension for my project.
I did it according to the documentation:
1. Using the Aimeos extension builder, I prepared an extension for my project called shop.
2. I received the shop.zip archive.
3. Created a folder /packages/shop (DocumentRoot of my site: /public). Unzipped shop.zip into the shop folder.
4. In composer.json added:
"repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom"
        "type": "path",
        "url": "packages/*"
5. Executed the command: composer req aimeos-extensions/shop
6. I got an error: PackageDiscoveryTrait.php line 332:
Could not find a version of package aimeos-extensions/shop matching your minimum-stability. Require it with an explicit version constraint allowing its desired stability.
Please help me to make the extension. And can it be done directly in the /shop folder?
iwpress
Re: Error creating a project extension
Post by iwpress » 05 Feb 2024, 22:08
Can someone who knows about this help me?
Post by aimeos » 05 Feb 2024, 22:32
Did you create a sub-directory in the existing ./packages/ directory for your extension and unzipped the generated extension there? The ./packages/ directory is in the root directory of your Laravel application (not in the ./public/ directory!)
iwpress
Post by iwpress » 05 Feb 2024, 23:34
Thank you.
That's exactly what I did.
Lowered "minimum-stability" to 'dev' and the error disappeared.
On package mcarrowsmith-packages/shopify-graphql-client (v1.1) prompts for login and password.
Is this a paid package?
I correctly chose Aimeos 2023.x extension, maybe I should choose Laravel theme 2023.x extension for aimeos-laravel?
Post by aimeos » 07 Feb 2024, 09:06
The mentioned package isn't one of ours and we also don't require it.
iwpress
Post by iwpress » 08 Feb 2024, 08:56
Thank you.
BR
iwpress
Post by iwpress » 08 Feb 2024, 09:31
I'm sorry,
I made so many attempts that unnecessary dependencies appeared: mcarrowsmith-packages.
Actually, the problem was that when I switched to Laravel 10, I set 'minimum-stability' to 'stable'.
Now I installed 'dev' and did the installation from the beginning. And, praise be to Aimeos, the extension is installed without any errors. My problem is solved.
I installed the Aimeos 2023.x extension for aimeos-laravel.
Thank you very much for your help and detailed replies.
Best Regards.
Post by aimeos » 09 Feb 2024, 10:11
iwpress wrote: 08 Feb 2024, 08:56 I correctly chose Aimeos 2023.x extension, maybe I should choose Laravel theme 2023.x extension for aimeos-laravel?
The Laravel theme extension is only required if you want to offer a custom theme which can be selected in the admin backend. For all other requirements, the standard Aimeos extensions are sufficient.
iwpress
Post by iwpress » 09 Feb 2024, 18:00
Thank you, I'll keep that in mind.
