View [auth.login] not found
edwinnnss
Post by edwinnnss » 30 Mar 2016, 05:13
I have read guides and process step by step, but when finished and I want to login to admin page, I got this message
InvalidArgumentException in FileViewFinder.php line 137:
View [auth.login] not found.
Can you help me how to solve this error ?
Re: View [auth.login] not found
Post by aimeos » 30 Mar 2016, 07:31
Which Laravel version are you using?
If you are using 5.1, you have to create your own view files in "./resources/views/auth/" like described in the Laravel docs: https://laravel.com/docs/5.1/authentica ... uded-views
edwinnnss
Post by edwinnnss » 30 Mar 2016, 10:11
I'm sorry my mistake.
I forget to do php artisan make:auth
