Login - local.site.code
beenzu
Post by beenzu » 19 Feb 2024, 08:08
aimeos 23.10 Laravel 23.7 PhP:8.2.12 win 10
I am trying Aimeos-Laravel for the first timeI. I think I have a config error. I install Aimeos-Laravel ok. But when I start 127.0.0.1:8000 I get the Laravel dashboard and not aimeos web sit. When I try to login I get the following error:
No item found for conditions: Array ( [locale.site.code] => login ).
I am able to run myshop ok, but failing config og aimeos-laravel. Please assist
Re: Login - local.site.code
Post by aimeos » 19 Feb 2024, 08:11
Did you install the Aimeos distribution or have you added the Aimeos package to your own existing Laravel application?
beenzu
Post by beenzu » 19 Feb 2024, 08:17
I installed the Aimeos distribution
Post by aimeos » 19 Feb 2024, 08:21
Can you install it from scratch and paste the output here? We would like to see what you've exactly installed and if there's any suspicious output.
