New model in new context not saving
jafo66
Post by jafo66 » 25 Mar 2024, 01:54
I have been able to create a model in my extension. In my project which references my extension, I'm able to get model and query the database successfully.
What I'm not understanding is why I'm not able to save a record. There is no exception (it is in a try/catch just to be sure)
        try {
            // see if seasons works
            $seasonManager = MShop::create($context, 'season');
            $search = $seasonManager->filter(true);
            $search->slice(0, 10000);
            $seaons = $seasonManager->search($search);
            Log::info('Seasons found: ' . json_encode($seaons));
            $newitem = $seasonManager->create([
                'name' => '2024 Season - March 3x3',
                'code' => '2024spring3x3',
                'status' => 1,
            $newitems = $seasonManager->save($newitem);
            Log::info('Seasons created: ' . json_encode($newitems));
        catch (\Exception $e) {
            Log::error($e->getMessage());
Key Details:
  • Model is here (inside my extension): ./src/MShop/Season/Manager/Standard.php. It is the copy of the example in the docs
    namespace Aimeos\MShop\Season\Manager;
    class Standard
        extends \Aimeos\MShop\Common\Manager\Base
        implements \Aimeos\MShop\Common\Manager\Iface
        public function getSaveAttributes() : array
            return $this->createAttributes( [
                'name' => [
                    'type' => 'string',
                    'required' => true,
                    'unique' => false
                'code' => [
                    'type' => 'string',
                    'required' => true,
                    'unique' => true
                'status' => [
                    'type' => 'int',
                    'required' => true
  • The table is mshop_season - which all seemed to work as expected
  • I have changed the logging to level 7, but I'm not seeing anything in the logs that would tell me what the problem is
Let me know if you have any thoughts as to why I'm able to query but not save?
Re: New model in new context not saving
Post by aimeos » 27 Mar 2024, 09:57
Passing data directly to the create() method doesn't set the internal modified state so save() skips sending the data to the database. Use fromArray() instead:
            $data = [
                'status' => 1,
            $newitem = $seasonManager->create()->fromArray( $data );
