PHP setting for "upload_max_filesize" is too low
skeeperloyaltie
Post by skeeperloyaltie » 03 Apr 2024, 14:51
I am meeting this error every time i try to upload a video for the header carousel How can I fix this.. am running Aimeos as a standalone so its not in nginx or Apache but probably using Apache I'm not sure
I just run
PHP artisan serves on the terminal in my Documents directory and I encounter this error
Re: PHP setting for "upload_max_filesize" is too low
Post by aimeos » 04 Apr 2024, 13:36
The standard PHP settings are too low for uploading your file. Instead of using "artisan serve", you can directly use the PHP binary and add these configuration settings:
php -S 127.0.0.1:8000 -t public -d post_max_size=50M -d upload_max_filesize=50M
