Integrity constraint violation when importing existing products, categories, etc.
kdim95
Post by kdim95 » 04 Apr 2024, 12:46
Laravel framework version: 10.16.1
Aimeos Laravel version: 2023.04.*
PHP Version: 8.2.17
Environment: Linux
I'm getting integrity constraint errors when importing XMLs for products, categories, etc.
The expected behavior is for the products, categegories, etc. to be updated if they already exist.
It even says so in the documentation here: https://aimeos.org/docs/2023.x/cronjobs ... ml-import/
"You can use the product import job controller for XML files to import/update the products."
For example, I get Integrity constraint violation: 1062 Duplicate entry when attempting to import a catalog item, which already exists in the database.
Can you help me out understanding if this is supposed to happen and why it's happening?
Best regards
Re: Integrity constraint violation when importing existing products, categories, etc.
Post by aimeos » 04 Apr 2024, 13:40
Can you provide a minimal XML which reproduces the problem?
kdim95
Post by kdim95 » 04 Apr 2024, 15:02
I get Integrity constraint violation even when attempting to import the root catalog item:
Minimal XML:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<catalog>
    <catalogitem ref="home">
        <catalog.code><![CDATA[Home]]></catalog.code>
        <catalog.label><![CDATA[Home]]></catalog.label>
        <catalog.status><![CDATA[1]]></catalog.status>
    </catalogitem>
</catalog>
Error:
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'Home-1.' for key 'unq_mscat_code_sid':
        INSERT INTO "mshop_catalog" (
                "siteid", "label", "code", "status", "parentid", "level",
                "nleft", "nright", "config", "mtime", "ctime", "editor", "target"
        ) VALUES (
                '1.', ?, ?, ?, ?, ?, ?, ?, '', '1970-01-01 00:00:00', '1970-01-01 00:00:00', '', ''
["Home","Home",1,0,0,2325,2326]
Post by aimeos » 07 Apr 2024, 11:45
kdim95 wrote: 04 Apr 2024, 15:02
<catalog>
    </catalogitem>
</catalog>
"ref" and "catalog.code" must be the same case (lower case).
kdim95
Post by kdim95 » 08 Apr 2024, 09:14
Fixing the capitalization worked for the root catalog item, but the error occurs for the children as well
Does this mean that the children also have to have ref="" parameter matching the catalog.code?
Adding this parameter to the child <catalogitem> tags seems to work, so I think the docs might be wrong.
I'm looking at the docs here and I see no ref="" parameter in the child items in the example:
Here is an example without ref="" attribute on subcategories (throws integrity constraint violation):
<catalog>
        <catalog.code><![CDATA[home]]></catalog.code>
        <catalog.label><![CDATA[Root category]]></catalog.label>
    </catalogitem>
    <catalog>
        <catalogitem>
            <catalog.code><![CDATA[cat-1]]></catalog.code>
            <catalog.label><![CDATA[Category 1]]></catalog.label>
        </catalogitem>
        <catalog>
            <catalogitem>
                <catalog.code><![CDATA[cat-2]]></catalog.code>
                <catalog.label><![CDATA[Subcategory 1]]></catalog.label>
            </catalogitem>
            <catalogitem>
                <catalog.code><![CDATA[cat-3]]></catalog.code>
                <catalog.label><![CDATA[Subcategory 2]]></catalog.label>
            </catalogitem>
        </catalog>
    </catalog>
</catalog>
Here is an example with ref="" attributes included (categories update properly with no errors):
<catalog>
    </catalogitem>
    <catalog>
        <catalogitem ref="cat-1">
        </catalogitem>
        <catalog>
            <catalogitem ref="cat-2">
            </catalogitem>
            <catalogitem ref="cat-3">
            </catalogitem>
        </catalog>
    </catalog>
</catalog>
Best regards
Post by aimeos » 08 Apr 2024, 10:17
kdim95 wrote: 08 Apr 2024, 09:14 Fixing the capitalization worked for the root catalog item, but the error occurs for the children as well
Yes, for updates the "ref" parameter is required, for initial insertion it can be omitted.
We've updated the docs accordingly like you've suggested. Thanks!
kdim95
Post by kdim95 » 08 Apr 2024, 13:16
Thank you, this makes it clear about the category items.
I am experiencing more integrity constraint violations when importing existing products.
This time it seems to be coming from the product properties under the <property> tag.
This is the error I get:
Integrity constraint violation: 1062 Duplicate entry '19-product/property-default--1.' for key 'unq_msproli_pid_dm_ty_rid_sid'
Here is how to reproduce the error:
  • Import the example XML
  • Change the package-weight property value from 50.00 to 60.00
  • Import the changed example XML again
Expected behavior:
  • The property value should update based on the passed property type and language
  • Multiple rows for one property.type shouldn't be added
Here is a Minimal XML taken from the documentation:
<products>
  <!-- List of product items with unique code as "ref" -->
  <productitem ref="TEST-ARTICLE">
    <!-- Required, possible values: "default" (article), "bundle", "select", "voucher" -->
    <product.type><![CDATA[default]]></product.type>
    <!-- Required, unique SKU of the product -->
    <product.code><![CDATA[TEST-ARTICLE]]></product.code>
    <!-- Required, label of the product, used if no language specific name is avialable -->
    <product.label><![CDATA[Test article]]></product.label>
    <!-- Optional, possible values: 1 = enabled (default), 0 = disabled, -1 = review, -2 =archived -->
    <product.status><![CDATA[1]]></product.status>
    <!-- Optional, JSON encoded (multi-dimensional) key/value pairs with arbitrary settings -->
    <product.config><![CDATA[{"key": "value"}]]></product.config>
    <!-- Optional, start ISO date/time value (YYYY-MM-DDTHH:mm:ss) the product is available from -->
    <product.datestart><![CDATA[2000-01-01T00:00:00]]></product.datestart>
    <!-- Optional, end ISO date/time value (YYYY-MM-DDTHH:mm:ss) the product is available to -->
    <product.dateend><![CDATA[2000-01-01T23:59:59]]></product.dateend>
    <!-- Optional, list of product property items -->
    <property>
        <!-- Optional, arbitrary product properties -->
        <propertyitem>
            <!-- Required, any available product property type like "package-height", "package-length", "package-width", "package-weight" -->
            <product.property.type><![CDATA[package-weight]]></product.property.type>
            <!-- Required, two letter ISO language code or empty for no language -->
            <product.property.languageid><![CDATA[]]></product.property.languageid>
            <!-- Required, value of the product property -->
            <product.property.value><![CDATA[50.00]]></product.property.value>
        </propertyitem>
        <!-- more property items -->
    </property>
  </productitem>
</products>
Post by aimeos » 08 Apr 2024, 19:06
We can't reproduce the problem with the product property update with your file. According to the error message, the property was tried to be imported as referenced item in mshop_product_list. Did you mixed up <lists> with <property> tags?
kdim95
Post by kdim95 » 09 Apr 2024, 09:08
aimeos wrote: 08 Apr 2024, 19:06 Did you mixed up <lists> with <property> tags?
I'm not sure. How can I checked if I "mixed up <lists> with <property> tags" ?
Are you running the import on the same Aimeos version as mine?
Post by aimeos » 09 Apr 2024, 09:18
We only use 2023.10 LTS as 2023.04 isn't supported any more.
