How to set elastic search custom field type?
kdim95
Post by kdim95 » 05 Apr 2024, 12:45
Laravel framework version: 10.16.1
Aimeos Laravel version: 2023.04.*
PHP Version: 10.46.0
Environment: Linux
I want to set a custom field to be of type "date" in the elastic search mappings.
The reason behind this is because filtering results based on date breaks with custom attributes added to the decorator.
I found the configuration file here:
/vendor/aimeoscom/ai-elastic/setup/default/elastic
I added my own mapping and it works:
'myfield' => [ 'type' => 'date', 'format' => 'yyyy-MM-dd HH:mm:ss' ]
I want to know how to add this mapping the correct way, so it won't disappear when updating the package.
Best regards
nos3
Re: How to set elastic search custom field type?
Post by nos3 » 07 Apr 2024, 11:49
Create e.g. a ./setup/default/elastic/product.php in your own extension and add your new field there:
return array(
	'base' => function ( array $mappings ) {
		$map = [
			'base' => [
				'properties' => [
		return array_replace_recursive( $mappings, $map );
kdim95
Post by kdim95 » 08 Apr 2024, 08:41
Thank you @nos3, works great
<?php
return [
    'base' => function( array $mappings ) {
        $map = [
            'base' => [
                'properties' => [
