GraphQL: Cannot query field "id" on type "searchProducttypeOutput"
kdim95
Post by kdim95 » 26 Apr 2024, 04:26
Laravel framework version: 11.3.1
Aimeos Laravel version: 2024.04
PHP Version: 8.2.17
Environment: Linux
I'm getting this error:
Code snippet, used in custom.js in my extension:
let filter = {
	"==": {"product.type.domain":"product"}
const fstr = JSON.stringify(JSON.stringify(filter));
const body = JSON.stringify({'query':
`query {
	searchProductTypes(filter: ` + fstr + `) {
	id
	code
	label
fetch($('.aimeos').data('graphql'), {
	method: 'POST',
	credentials: 'same-origin',
	headers: { // Laravel only
		'X-CSRF-TOKEN': $('meta[name="csrf-token"]').attr('content')
	body: body
}).then(response => {
	return response.json();
}).then(data => {
	console.log(data);
I'm using the example from here:
https://aimeos.org/docs/2024.x/admin/graphql/type/
Best regards
Re: GraphQL: Cannot query field "id" on type "searchProducttypeOutput"
Post by aimeos » 26 Apr 2024, 11:20
Sorry, the documentation wasn't up to date and the correct query in 2024.x+ is:
query {
  searchProductTypes(filter: "{\"==\": {\"product.type.domain\":\"product\"}}") {
    items {
      id
      code
      label
    total
The "total" property is optional and you should only add it if you need the total number of items matching the query for pagination.
kdim95
Post by kdim95 » 26 Apr 2024, 11:53
Thank you, I got it working.
For some reason, when adding the filter parameter and using the query with Aimeos.query(), it requires the content of "filter" to be escaped with double slash, not single, don't know why that is, but it works now.
const result = await Aimeos.query(`query {
	searchProductTypes( filter: "{ \\"==\\": { \\"product.type.domain\\": \\"product\\" } }" ) {
		items {
			id
			code
			label
		total
Best regards
Post by aimeos » 26 Apr 2024, 12:12
Thanks for the hint, the docs has been adapted accordingly!
