GraphQL: Products "Bought together", "Suggestion" not loading
kdim95
Post by kdim95 » 26 Apr 2024, 14:04
Laravel framework version: 11.3.1
Aimeos Laravel version: 2024.04
PHP Version: 8.2.17
Environment: Linux
In the administration, when I go to a product -> products and try to add a "Bought together" product or "Suggestion" product, they are not loading when I click the dropdown or try to search. In the console I get "GraphQL query failed".
    "errors": [
            "message": "Internal server error",
            "locations": [
                    "line": 2,
                    "column": 7
            "path": [
                "searchProducts"
    "data": {
        "searchProducts": null
Best regards
Re: GraphQL: Products "Bought together", "Suggestion" not loading
Post by aimeos » 27 Apr 2024, 09:59
Thanks for the hint! The problem has been fixed in aimeos/ai-admin-jqadm:2024.04.x-dev and will be part of the next release. You can test yourself in the meantime by executing:
composer req aimeos/ai-admin-jqadm:2024.04.x-dev
kdim95
Post by kdim95 » 28 Apr 2024, 00:19
I installed the x-dev package, problem is still not solved for me, I get the exact same error.
Post by aimeos » 28 Apr 2024, 08:03
Are there any hints in the Log panel?
kdim95
Post by kdim95 » 29 Apr 2024, 13:32
Here is what I can tell you:
The error is the exact same as before.
In product.js you are filtering products by null.
This means that if you haven't typed anything in the related product search and hit the dropdown, you get GraphQL error.
I changed it locally in product.js:
From this:
const filter = {
		{'>': {'product.status': 0}},
			{'=~': {'product.label': input}},
			{'=~': {'product.code': input}},
			{'==': {'product.id': input}}
To this and it works, can you confirm?
It's so products are not filtered by null when there's nothing in the input.
let filter = {
if(input) {
	filter['&&'].push({
https://github.com/aimeos/ai-admin-jqad ... ct.js#L678
Post by aimeos » 30 Apr 2024, 07:36
Thanks, we've changed that now and it's available in aimeos/ai-admin-jqadm:2024.04.x-dev until a new release is tagged.
