airoute not producing https links
jafo66
Post by jafo66 » 29 Apr 2024, 17:58
In deploying my app into a docker container, I have it exposed on port 443 with a valid certificate. The site won't work because it seems to be responding with URLs as http://<server_name> instead of https://<server_name>. Meaning, I get HTML returned the browser is blocking the non-secured links which is basically everything.
I have done the following:
  • Changed the APP_URL to be https://<server_name> in the .env file
  • Ensured the host (docker) and deployed app instance (inside of Azure) is listening on 443
  • added the ASSET_URL to the .env file
Any ideas about how I could get the airoute to generate the proper links?
Re: airoute not producing https links
Post by aimeos » 30 Apr 2024, 07:00
airoute() uses the Laravel routing infrastructure. Usually, setting APP_URL to a https URL works. If not, check the Laravel documentation and ask in the Laravel forums for help.
