SQLSRV configuration.
syedaliiftikhar
Post by syedaliiftikhar » 08 May 2024, 14:23
I'm trying to connect with sqlsrv. Could you provide guidance on the correct configuration pattern in config/shop.php? I'm encountering an issue with trust_server_certificate.
Re: SQLSRV configuration.
Post by aimeos » 08 May 2024, 17:40
The unit tests use this configuration:
https://github.com/aimeos/aimeos-core/b ... ig.yml#L25
syedaliiftikhar
Post by syedaliiftikhar » 08 May 2024, 18:01
I'm adding configuration in shop.php, but it's giving me an error regarding the SSL certificate. When I use the Laravel Facade DB to connect directly from database.php, it works fine, but when using the Aimeos config, it doesn't work.
Post by aimeos » 09 May 2024, 07:51
The Aimeos database layer uses PDO directly. Check the internet if there are any special settings necessary for SQL server connections with TLS enabled.
