Upgrade Issues
jafo66
Upgrade Issues
Post by jafo66 » 18 May 2024, 15:40
In doing the upgrade from 2023.10 to 2024.04, my admin menu icons broke. I had them in my extension in the custom.css file (and they were working).
Previous css:
.aimeos .sidebar-menu li .tree-menu .menuitem-geolocation i.icon:before {
    content: url("/images/geolocation.svg");
Any idea why this is no longer working now?
jafo66
Re: Upgrade Issues
Post by jafo66 » 21 May 2024, 15:29
It looks like the custom.css from my extension isn't being loaded. Is there a change after the upgrade that I need to implement?
Re: Upgrade Issues
Post by aimeos » 22 May 2024, 12:32
Check if the CSS selector is still correct as there have been changes regarding the used CSS selectors.
jafo66
Re: Upgrade Issues
Post by jafo66 » 22 May 2024, 18:30
I have checked it to ensure it is still correct and have tried other variations. I'm not seeing the CSS coming in from the server even after doing a clear of cache and reload.
Re: Upgrade Issues
Post by aimeos » 23 May 2024, 11:26
Most likely, you haven't upgraded your own extension. The file names in the manifest.jsb2 file must be like that now:
- https://github.com/aimeos/aimeos-core/b ... st.jsb2#L6
- https://github.com/aimeos/aimeos-core/b ... t.jsb2#L14
jafo66
Re: Upgrade Issues
Post by jafo66 » 28 May 2024, 22:01
This worked, but note I had to change the name from "extenstion-name.js" to "index-js" for it to work properly. That is because the index.blade.php is looking specifically for index-js name and no other names are considered for loading. Same is true for the index.css.
