Locale item for site "test-site" not found on fresh aimeos install
lockhart97
Laravel: 11.0
Aimeos: 2024.04
PHP: 8.2
Environment: Linux
I am stuck in very peculiar problem. I was developing with aimeos and everything was working perfectly. Then there was need to work on different feature and since I use worktrees for my project, I created a new worktree for my new feature. I had to roll back to fresh laravel installation as I wanted to check something. After that I did a fresh install of aimeos in the temp worktree, but running command returns error. I tried this commad with fresh DB as well.
Error:
But, my previous installation of aimeos in another working is working fine. I have even replaced the composer.json in my temp-wroktree, but still same error. I tried to dig but could not find a solution. Can you please look into it? Let me know if you need more information.
Aimeos: 2024.04
PHP: 8.2
Environment: Linux
php artisan aimeos:setup test-siteError:
at vendor/aimeos/aimeos-core/src/MShop/Locale/Manager/Standard.php:637
633▕ return $this->createItemBase( ['locale.siteid' => $siteId], $siteItem, $sites );
634▕ }
635▕
636▕ $msg = $this->context()->translate( 'mshop', 'Locale item for site "%1$s" not found' );
➜ 637▕ throw new \Aimeos\MShop\Locale\Exception( sprintf( $msg, $site ) );
638▕ }
639▕
640▕
641▕ /**
+24 vendor frames
25 artisan:13
Illuminate\Foundation\Application::handleCommand(Object(Symfony\Component\Console\Input\ArgvInput))
Re: Locale item for site "test-site" not found on fresh aimeos install
We can confirm the problem and are working on a solution.
Problem has been fixed in latest aimeos/aimeos-core package. Please run "composer up" to get the latest version.
lockhart97
THanks I will check in my setup and will let you know.aimeos wrote: 23 May 2024, 07:35 Problem has been fixed in latest aimeos/aimeos-core package. Please run "composer up" to get the latest version.
