GraphQL errors with the free shipping plugin
kdim95
Post by kdim95 » 21 May 2024, 15:40
Laravel framework version: 11.6.0
Aimeos Laravel version: 2024.04
PHP Version: 8.2.18
Environment: Linux
The free shipping plugin can't be used.
How to reproduce:
1) Create a new plugin
2) Select plugin type "FreeShipping"
This is the received in the response:
{"errors":[{"message":"Internal server error","locations":[{"line":6,"column":7}],"path":["getPluginConfig",0,"default"]}],"data":{"getPluginConfig":[{"code":"threshold","label":"Free shipping threshold per currency","type":"map","default":null,"required":false}]}}
Re: GraphQL errors with the free shipping plugin
Post by aimeos » 22 May 2024, 13:02
"FreeShipping" isn't a plugin that's available in Aimeos:
https://aimeos.org/docs/latest/manual/plugins/
kdim95
Post by kdim95 » 22 May 2024, 13:15
Sorry I mean the "Shipping" plugin.
I have an override of this plugin, but on the original plugin I get the same problem.
graphql request:
"query {\n\t\t\t\t\tgetPluginConfig(provider: \"Shipping\", type: \"order\") {\n\t\t\t\t\t\tcode\n\t\t\t\t\t\tlabel\n\t\t\t\t\t\ttype\n\t\t\t\t\t\tdefault\n\t\t\t\t\t\trequired\n\t\t\t\t\t}\n\t\t\t\t}"
graphql response:
kdim95
Post by kdim95 » 22 May 2024, 14:06
It appears to have something to do with the $beConfig['default'] being an array.
Post by aimeos » 23 May 2024, 09:36
The problem has been fixed. Please run "composer up" to get the latest version.
