Install Aimeos in separate database
rhand
Post by rhand » 28 May 2024, 04:58
Trying to install Aimeos in different database from core Laravel app database but I only get migration table
Did add
DB_CONNECTION=mysql_aimeos
DB_AIMEOS_HOST=localhost
DB_AIMEOS_DATABASE=aimeos
DB_AIMEOS_USERNAME=root
DB_AIMEOS_PASSWORD=
DB_AIMEOS_PORT=3306
and in database/config.php I added
'mysql_aimeos' => [
            'driver' => 'mysql',
            'host' => env('DB_AIMEOS_HOST', '127.0.0.1'),
            'port' => env('DB_AIMEOS_PORT', '3306'),
            'database' => env('DB_AIMEOS_DATABASE', 'forge'),
            'username' => env('DB_AIMEOS_USERNAME', 'forge'),
            'password' => env('DB_AIMEOS_PASSWORD', ''),
            'charset' => 'utf8mb4',
            'collation' => 'utf8mb4_unicode_ci',
            'prefix' => '',
            'prefix_indexes' => true,
            'strict' => true,
            'engine' => null,
            'options' => extension_loaded('pdo_mysql') ? array_filter([
                PDO::MYSQL_ATTR_SSL_CA => env('MYSQL_ATTR_SSL_CA'),
Sother tables are added besides migrations table and an invites table based on another package that I do not need in this database and I get this error post
php artisan migrate  --database=mysql_aimeos
   INFO  Preparing database.
  Creating migration table ............................................................................................................... 37ms DONE
   INFO  Running migrations.
  2017_04_04_185723_create_invites_table ................................................................................................ 127ms DONE
And yes I did run
composer update -W
php artisan vendor:publish --tag=config --tag=public
Re: Install Aimeos in separate database
Post by aimeos » 28 May 2024, 07:41
You have to adapt the database configuration in the ./config/shop.php file:
https://github.com/aimeos/aimeos-larave ... hp#L51-L66
rhand
Post by rhand » 28 May 2024, 09:32
I added
'resource' => [
		'db' => [
			'adapter' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.driver', 'mysql' ),
			'host' => config('DB_AIMEOS_HOST', '127.0.0.1'),
			'port' => config('DB_AIMEOS_PORT', '3306'),
			'socket' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.unix_socket', '' ),
			'database' => config('DB_AIMEOS_DATABASE', 'aimeos'),
			'username' => config('DB_AIMEOS_USERNAME', 'forge'),
			'password' => config('DB_AIMEOS_PASSWORD', ''),
			'stmt' => config( 'database.default', 'mysql' ) === 'mysql' ? ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"] : [],
			'limit' => 3, // maximum number of concurrent database connections
			'defaultTableOptions' => [
				'charset' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.charset' ),
				'collate' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.collation' ),
			'driverOptions' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.options' ),
to config/shop.php. Already had
'mysql_aimeos' => [
            'prefix' => '',
            'strict' => true,
            'engine' => null,
in config/database.php but I guess that did not work. However, still getting nothing extra on php artisan migrate --database=mysql_aimeos so I think I need something to load `DB_CONNECTION=mysql_aimeos` as well
rhand
Post by rhand » 28 May 2024, 10:13
Then I ran
php artisan aimeos:setup
   Aimeos\Base\DB\Exception
  An exception occurred in the driver: SQLSTATE[HY000] [1044] Access denied for user ''@'localhost' to database 'aimeos': SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'
  at vendor/aimeos/aimeos-base/src/DB/Statement/DBAL/Simple.php:75
     71▕        {
     72▕                try {
     73▕                        $result = $this->getConnection()->getRawObject()->getWrappedConnection()->query( $this->sql );
     74▕                } catch( \Doctrine\DBAL\Driver\Exception $e ) {
  ➜  75▕                        throw new \Aimeos\Base\DB\Exception( $e->getMessage() . ': ' . $this->sql, $e->getCode() );
     76▕                }
     77▕
     78▕                return new \Aimeos\Base\DB\Result\DBAL( $result );
     79▕        }
      +22 vendor frames
  23  artisan:35
      Illuminate\Foundation\Console\Kernel::handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
So perhaps something else I still missed?
Post by aimeos » 29 May 2024, 07:02
According to your error message, the user name isn't passed for login into the database.
rhand
Post by rhand » 30 May 2024, 03:05
The Aimeos shop.php configuration file with
did not pass on data. Or it did not show what user used in the mentioned error. I assumed it would load data from .env but it did not hence the `''` without username mentioned. When I used root as user in `config/shop.php`
 'resource' => [
        'db' => [
            'adapter' => config('database.connections.'.config('database.default', 'mysql').'.driver', 'mysql'),
            'host' => config('DB_AIMEOS_HOST', 'localhost'),
            'socket' => config('database.connections.'.config('database.default', 'mysql').'.unix_socket', ''),
            'username' => config('DB_AIMEOS_USERNAME', 'root'),
            'stmt' => config('database.default', 'mysql') === 'mysql' ? ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"] : [],
                'charset' => config('database.connections.'.config('database.default', 'mysql').'.charset'),
                'collate' => config('database.connections.'.config('database.default', 'mysql').'.collation'),
            'driverOptions' => config('database.connections.'.config('database.default', 'mysql').'.options'),
all was well and migrations ran. Very odd . When I checked the value
php artisan tinker
Psy Shell v0.12.3 (PHP 8.2.15 — cli) by Justin Hileman
> echo getenv('DB_AIMEOS_USERNAME');
root⏎
it was fine and loaded. So what did
not first try and get aimeos username from .env:
# DB_CONNECTION=mysql_aimeos
DB_AIMEOS_CONNECTION=mysql_aimeos
DB_AIMEOS_PORT=3306
DB_AIMEOS_PASSWORD=
rhand
Post by rhand » 30 May 2024, 03:43
My bad. I needed env:
 'resource' => [
        'db' => [
            'adapter' => config('database.connections.' . config('database.default', 'mysql') . '.driver', 'mysql'),
            'host' => env('DB_AIMEOS_HOST', 'localhost'),
            'socket' => config('database.connections.' . config('database.default', 'mysql') . '.unix_socket', ''),
            'database' => env('DB_AIMEOS_DATABASE', 'aimeos'),
                'charset' => config('database.connections.' . config('database.default', 'mysql') . '.charset'),
                'collate' => config('database.connections.' . config('database.default', 'mysql') . '.collation'),
            'driverOptions' => config('database.connections.' . config('database.default', 'mysql') . '.options'),
That did allow environmental values to load.. of course. Thanks for all your input.
