Multi Vendor Setups Only
rhand
Post by rhand » 30 May 2024, 06:54
I read at https://aimeos.org/docs/2024.x/laravel/ ... e-new-site that
php artisan aimeos:setup <site code> [<template site>]
can be used to create a multi vendor site. If we do not want a general site for the whole site does that mean we should not run
? Or is still needed for general setup?
Two, what kind of site code should be added? And what template site data? Assume it is not
php artisan aimeos:setup domain.com my-template
or is it?
When I read
The value for <site code> can be either a new site code for creating a new site or an existing site code for updating a site. The <template site> code is optional and tells the setup command which site template to use as reference when creating a new site (currently "default", "unittest" and "unitperf" are available as templates). If no value for <template site> is given, "default" is used.
I think we can use
php artisan aimeos:setup <site code> default
but not sure what to add for site code. What to add? When I check
vendor/aimeos/aimeos-laravel/src/Command/SetupCommand.php
I see
if( ( $site = $this->argument( 'site' ) ) === null ) {
	$site = config( 'shop.mshop.locale.site', 'default' );
but not sure where that view or part `shop.mshop.locale.site` goes to. And that is for when no site is set so only for core shop or shop without vendors.. But in config/shop.php I do see
'mshop' => [
        'locale' => [
          // 'site' => '<custom site code>', // used instead of "default"
Three , if I just want to add database data for a multi vendor user so he can add products and load data using JSOn on our own editor grid, how would I go about that? Can I run a command to just do database data setup and then use some JSON call?
rhand
Re: Multi Vendor Setups Only
Post by rhand » 30 May 2024, 10:00
Did a test
php artisan aimeos:setup domein.nl default --v=vv
Initializing or updating the Aimeos database tables for site "domein.nl"
Migrating: vendor/aimeos/aimeos-core/setup/TypesMigrateColumns.php
Migrate type columns
  Add new type columns
    Checking table "mshop_attribute":
    Checking table "mshop_attribute_list":
    Checking table "mshop_attribute_property":
    Checking table "mshop_catalog_list":
    Checking table "mshop_customer_list":
    Checking table "mshop_customer_property":
    Checking table "mshop_media":
    Checking table "mshop_media_list":
    Checking table "mshop_media_property":
    Checking table "mshop_plugin":
    Checking table "mshop_price":
    Checking table "mshop_price_list":
    Checking table "mshop_product":
    Checking table "mshop_product_list":
    Checking table "mshop_product_property":
    Checking table "mshop_service":
    Checking table "mshop_service_list":
    Checking table "mshop_stock":
    Checking table "mshop_supplier_list":
    Checking table "mshop_tag":
    Checking table "mshop_text":
    Checking table "mshop_text_list":
  Drop old unique indexes
    Checking index "unq_msattr_sid_dom_cod_tid":
    Checking index "unq_msattli_sid_dm_rid_tid_pid":
    Checking index "unq_msattpr_sid_tid_lid_value":
    Checking index "unq_mscatli_sid_dm_rid_tid_pid":
    Checking index "unq_mscusli_sid_dm_rid_tid_pid":
    Checking index "unq_mcuspr_sid_tid_lid_value":
    Checking index "unq_msmedli_sid_dm_rid_tid_pid":
    Checking index "unq_msmedpr_sid_tid_lid_value":
    Checking index "unq_msplu_sid_tid_prov":
    Checking index "unq_msprili_sid_dm_rid_tid_pid":
    Checking index "unq_msproli_sid_dm_rid_tid_pid":
    Checking index "unq_mspropr_sid_tid_lid_value":
    Checking index "unq_msserli_sid_dm_rid_tid_pid":
    Checking index "unq_mssto_sid_pcode_tid":
    Checking index "unq_mssupli_sid_dm_rid_tid_pid":
    Checking index "unq_mstag_sid_dom_tid_lid_lab":
    Checking index "unq_mstexli_sid_dm_rid_tid_pid":
  Migrate typeid to type
Not sure yet where that new vendor site was added or will be loaded from. But command seemed to have done some work. And that on top of `php artisan aimeos:setup` I ran earlier.
How would I load JSON data from that shop into a Vue component or how do I add products from what url to this shop now?
Post by aimeos » 30 May 2024, 12:29
This updates the database structure for all sites:
This creates (or updates) a new site and adds the required default data, e.g. the types:
php artisan aimeos:setup domain.nl
This creates (or replaces) a site for unit testing:
php artisan aimeos:setup test unittest
rhand
Post by rhand » 31 May 2024, 00:11
I see. Thanks for explaining the commands . Did not know they were for setting up general Aimeos and updating database. And that that is the same for the separate site.
