Basket data in Payment Provider
lockhart97
Post by lockhart97 » 10 Jun 2024, 03:19
Laravel: 11.0
Aimeos: 2024.04
PHP: 8.2
Environment: Linux
Hello, I am developing a Payment Service provider. I need customer data to capture the payment as per the Payment gateway that I am using. The process method for the provider take Order Invoice object as parameter. How do I get basket address in the Payment provider. The addresses field in Order Invoice object is an empty array.
I thought using a decorator might solve this problem. Can you please point me right direction as to how get basket address in Payment provider using decorators or without them?
lockhart97
Re: Basket data in Payment Provider
Post by lockhart97 » 12 Jun 2024, 03:58
I am using following method to access address in payment provider. Let me know if there is a better way
    public function process(
        \Aimeos\MShop\Order\Item\Iface $order,
        array $params = []
    ): ?\Aimeos\MShop\Common\Helper\Form\Iface {
        // perform your actions
        $context = $this->context();
        $orderId = $params["order.id"];
        $orderAddress = \Aimeos\Controller\Frontend::create( $context, 'basket' )->load( $orderId, ['order/address'], false );
        return parent::process($order, $params);
Post by aimeos » 12 Jun 2024, 10:45
The order items already contains the address and you can use this to get the billing address:
$order->getAddress('payment');
See: https://github.com/aimeos/aimeos-core/b ... e.php#L274
lockhart97
Post by lockhart97 » 12 Jun 2024, 12:04
This does not work. It returns null.
lockhart97
Post by lockhart97 » 12 Jun 2024, 12:14
I am using JsonAPI to place order by making post request to basket. While writing a payment provider, the $order object is "order/service" object and it does not have address.
https://github.com/aimeos/ai-client-jso ... 11-L305C17
Post by aimeos » 13 Jun 2024, 10:52
Does it work for you if you replace the line which this one instead:
return \Aimeos\Controller\Frontend::create( $context, 'basket' )->load( $id, ['order/address', 'order/service'], false );
lockhart97
Post by lockhart97 » 17 Jun 2024, 16:06
Yes, this is exactly what I thought. However, implementing this would require changes to the core Aimeos codebase. If this solution is acceptable, I would like to submit a pull request to the Aimeos project.
Post by aimeos » 18 Jun 2024, 08:47
Yes, please create a PR and we are happy to merge the change into the core. It will be part of the next minor release then.
lockhart97
Post by lockhart97 » 18 Jun 2024, 13:39
Thank you for your response.
