How to: secure Aimeos-Laravel BE?
How to secure /admin of an Aimeos-Laravel installation?
There are different solutions I've seen with other applications.
What is the recommended or best way to do it and how (for each option) for Aimeos?
Thanks.
Thanks.
Re: How to: secure Aimeos-Laravel BE?
Laravel authentication is already securely designed so there's normally no need to improve that. If you are using Aimeos in very sensible environments, you can add 2FA in addition. There are tutorials for Laravel explaining how to add that.
Ok.aimeos wrote: 20 Jun 2024, 06:55Laravel authentication is already securely designed so there's normally no need to improve that.
Thanks for the hint.aimeos wrote: 20 Jun 2024, 06:55 If you are using Aimeos in very sensible environments, you can add 2FA in addition. There are tutorials for Laravel explaining how to add that.
