Admin List pages - change default number of results
jafo66
Post by jafo66 » 28 Jun 2024, 04:11
Is there a way to change the default number of rows returned in a list page from 25 to say 100? A follow up to that is how do I get the user's selection to stay at 100 once they have selected it?
I saw in the pagination.php file that there seems to be a look up for 'page/limit', but I didn't see how that would be set somewhere else.
Thanks!
Re: Admin List pages - change default number of results
Post by aimeos » 30 Jun 2024, 13:39
jafo66 wrote: 28 Jun 2024, 04:11 Is there a way to change the default number of rows returned in a list page from 25 to say 100? A follow up to that is how do I get the user's selection to stay at 100 once they have selected it?
The default number is not configurable and defined here:
https://github.com/aimeos/ai-admin-jqad ... e.php#L622
But once selected by the user, the choice remains for that list view as long as the session is available.
jafo66 wrote: 28 Jun 2024, 04:11 I saw in the pagination.php file that there seems to be a look up for 'page/limit', but I didn't see how that would be set somewhere else.
Only by a choice of the user. The "page[limit]" parameter is then part of the URL.
jafo66
Post by jafo66 » 02 Jul 2024, 04:08
Would you be willing to make that a configuration value instead of hard coded?
Post by aimeos » 02 Jul 2024, 08:13
Yes, no problem if you can create a PR for that :-)
