Show Product Subparts only for certain types of products
jafo66
Post by jafo66 » 22 Jul 2024, 12:53
I'm looking to show / hide certain subparts in the product page based on the type of product. Same functionality as seen with variants currently.
Is there a method to do that?
Thanks!
Re: Show Product Subparts only for certain types of products
Post by aimeos » 24 Jul 2024, 09:55
Display or hide tabs based on the selected product type is done here:
https://github.com/aimeos/ai-admin-jqad ... ct.js#L729
jafo66
Post by jafo66 » 24 Jul 2024, 12:08
Is there a good method to add an item to that list or do I need to override the entire product.js file? NOTE: to be clear, I'm trying to avoid having my own version of the file.
Post by aimeos » 25 Jul 2024, 10:08
You only need to overwrite the Aimeos.Product.Selection.init() method in your custom.js file
jafo66
Post by jafo66 » 27 Jul 2024, 19:40
This doesn't seem to be working, did I miss understand your reply?
const origInit = Aimeos.Product.Selection.init;
Aimeos.Product.Selection.init = () => {
	console.log('Yes, the override worked');
	const tab = $(".item-navbar .selection");
	['tournament', 'group', 'select'].includes($(".item-basic .item-type").val()) ? tab.show() : tab.hide();
	$(".item-product").on("change", ".item-basic .item-type", function() {
		['tournament', 'group', 'select'].includes($("option:selected", this).val()) ? tab.show() : tab.hide();
jafo66
Post by jafo66 » 27 Jul 2024, 19:47
here is my manifest file:
	"projectName": "tournament-management",
	"licenseText": "proprietary",
	"pkgs": [{
		"name": "tournament-management CSS",
		"file": "index-css",
		"isDebug": true,
		"fileIncludes": [{
			"text": "custom.css",
			"path": "themes/admin/jqadm/"
		"name": "tournament-management JS",
		"file": "index-js",
		"isDebug": true,
		"fileIncludes": [{
			"text": "custom.js",
		"name": "CYBN Components",
		"file": "components-js",
		"isDebug": true,
		"fileIncludes":
			"text": "searchable-select.js",
			"path": "js/components/"
			"text": "cybn-select.js",
	"resources" : []
jafo66
Post by jafo66 » 28 Jul 2024, 02:32
Nevermind... I had to force a hard reload on the page and then it worked properly.
